UCC28950 - Difference in design equation on technical documentation
Other Parts Discussed in Thread: UCC28950
I'm trying to work on Phase Shift Full Bridge (PSFB) Converter using UCC28950 controller chip and I'm confused as to which version of technical documentation do I have to refer. The link below shows two version of the document,
Moreover, I've noticed that there is difference in equation for calculating certain parameters. For example, on the latest document, there is difference in calculation of parameters on Lmag (Equation by factor of 2), Delta ILmag ( Equation 38 by factor of 2) and Lout (Equation 68 by factor of 2)
Could you explain the reason for difference of equation? Does the same equation mentioned on older version of technical documentation is still valid ?
Hope to hear from you soon.
Many Thanks
Mammen
