Please answer following question from customer.
Q1:
In case of VBAT is supplied form battery and battery is discharged, start-up rush current may cause battery voltage decrease to UVLO voltage and converter will shut down. After shut down battery voltage will rise (because of no load) and converter start again. And converter may continue to recycle shutdown and start.
Please advise if abnormal current that cause problem or damage will flow while above situation.
Q2:
Please advise the deglitch time of UVLO.
Best Regards.
