BQ24296 charger
Other Parts Discussed in Thread: BQ24296
i have a question about BQ24296.
when we turn off the host (it means no I2C communication) and charge the battery, how to work ?
Is BQ24296 working under default value ?
  • If the host already configured the charge profile (voltage and current) and watchdog is disabled, then charging will proceed based on the profile setting.
    If the watchdog is enabled, it would probably expired and reset all values to default and charger will proceed based on default values.
