TPS61169 - parallel connection
Other Parts Discussed in Thread: TPS61169, LM3697
Hi all
Would you mind if we ask TPS61169?
Please refer to the following file.
20160323_TPS61169.pdf
<Question1>
If our customer doesn't mind about difference in the brightness our customer's solution, is it possbile to use  parallel connection?
<Question2>
According to connection, is there switching frequency.However it is not matter, right?
Kind regards,
Hirotaka Matsumoto
  • Hi Matsumoto-san
    Yes the parallel connection is okay if the customer is not concerned about brightness difference in each string due to LED mis-matching. The switching waveforms you show look okay. If the customer has I2C capability I would recommend the LM3697 for the three sting driver.
    Randy Dahl
