TPS54318/PG NG in light load condition
Other Parts Discussed in Thread: TPS54318
Could you tell me about TPS54318?
To solve the problem that an output voltage fluctuates, when load fluctuates.
In that case,PG is NG status.
Will you check the attached file?
Customer is to manage the sequence using the PG.
Therefore, Customer want to solve this problem.
TPS54318.pdf
Is there the solution other than following methods?
・Adjust a phase compensation circuit
Could you give me your advice?
Yusuke/Japan Disty
