TPS62120 Bridge rectifier suggestions at input Compared with LTC3588-1 product
Other Parts Discussed in Thread: TPS62120, TPS62125
My piezoelectric vibration energy harvesting setup might require a bridge rectifier before input to TPS62120.  Does T.I. have a product similar to LTC3588-1 that has a bridge rectifier integrated? If not, are there any recommended bridge rectifiers that I can use for the TPS62120?   The PCB area is very very scarce so I'm trying to save as much space as possible, including the least number of external components as possible.
Thanks for your help.
  • We don't have anything with that function integrated that I am aware of.
    Be sure and take a look at the TPS62125. It supports a little bit higher Vin range as well as containing an integrated SVS to control the turn on and off based on the harvester's output voltage.
