Hi Tom,
I have a battery that we plan to use with the board design I sent last month or so, but I'm not sure what ID to use. I am currently using the default, but I don't necessarily feel its the correct one. Does the attached information provide you enough detail to let me know if the default ID is the correct one, or will I need to go through the Chem ID logging procedure to have TI either create a new ID, or match it with an existing ID?
As always, I appreciate your help.
- Jim Sheahan
3040127SH5C-datasheet - std - 550mah pack with PCB.pdfGE Battery Material Safety Data Sheet.pdf
