Hi
I have a question about equation of RT resistor.
On the data sheet, it is shown at
However it is the following equation actually.
(This is the equation of TPS57114)
Which is correct?
Koji Hamamoto
Hi
Which is correct?
Koji Hamamoto
The first equation is correct. The units of the constant in the numerator is (kohm * kHz^1.027). For the bottom equation it would be (kohm * kHz^1.0533). You don't really need to worry about it. Just use Fsw in kHz to get Rt in kohm.
