It is possible to synchronize clock of buck converter TPS65261-1 (master) and boost converter TPS43061 (slave)?
Thank you for your answer.
hi,
It is hard to approach your target.
TPS65261-1 is FCC mode, so LX is a stable signal which can used as clock for TPS43061. But the LX pulse will stop when OV, OC, OT occur.
Jason Wang
Zul fikri,
ROSC pin is only a stable voltage about 0.5V, so the cuicuit you mentioned can't be used.
Jason Wang
