Hello ,
I have a Engineering/ technical question in regards to the TPS73201 DBVR Low Dropout regulator .
At present we have a design here that uses this chip to charge a ML2430-CJ1 lithium Ion cell battery in circuit, in the end device.
My question is;
Can you describe if we could use this TPS73201 or similar chip to 'pre charge' a number of the ML2430-CJ1 Lithium Ion batteries before we install these batteries in actual units? In other words we would like to build up a que of pre charged batteries and then place them in the end devices.
Would like to charge them to 2.95 to 3.1 Volts and that is what the present circuit topology does for a 1x only ( in circuit).
Thanks much and if any additional information or questions I can give you just let me know.
Below is additional contact information for me as well.
Kirk Handahl
Test Engineer
Benchmark Electronics
Work Phone:507-535-4516
