Hello Elijah,
I have followed up regarding the calculator and we are going to have a revised version for the calculator soon.
However, just to clarify, in the Fly-Buck-Boost application, the primary (or the non-isolated side) output voltage is always negative. The bar chart in the calculator only shows the magnitude of the primary side voltage at present, hence the confusion.
Hope this clarifies.
Sourav
Hi Sourav,
I've found another bug in the calculator: Again with fly-buck-boost configuration it's impossible to change any of the resistor or cap values in the Compensation section. Any chance of a fix? (Or the password to override the restriction)
Thanks.
-Elijah
