TPS25942A variable current limit
Other Parts Discussed in Thread: TPS25942A
Does TPS25942A operate properly if I implement a variable current limit configuration?
The idea is to adopt the usual resistor to ground and another circuit in parallel to it with a analog switch and a resistor in series. This analog switch would be controlled by some logic, providing two different current limits. In our case, the selection would be according to power source.
Is there any problem in using TPS25942A this way, changing limit resistor "on the fly"? Will it operate correctly?
Need any additional information?
Thanks.
