Could you let us know what are the pinout for TO-220 of LM340-N? The information is not in the datasheet.
Mark
So are they have the same die, or using the same technology?
Mark
Hi Michael,
We need to calculate Theta heat sink using:
Pdmax= (Tjmax -Ta)/(Theta heat-sink + Theta case-to-heat sink + Theta junction-to-case)
We have every values except Theta case-to-heat sink.
Do you know if there any way to calculate Theta heat-sink?
By the way, the datasheet states Theta junction-to-case = 4 degree C/W for TO-220 on page 2. Where the Theta JC = 1.7 C/W from?
Mark
The 'case to heat-sink' interface is your choice: Thermal grease; Thermal Epoxy, Sil-Pad, etc.
Check Section 2.8 on page 4 of the TI Design Guide : Thermal Design Guide for KeyStone Devices (Literature # SPRABI3)
Theta-cs or case to heat sink thermal resistance can be approximated using the following formula:
CS = T / (k * A)
Where:
T = The thickness of interface layer between package and heat sink
k = The bulk thermal conductivity of the thermal interface material
A = The area over which the thermal interface material is applied
