Hi Sirs
what's the different between Pinstrap mode and NVM mode for TPS53641
and what's the priority between pin strap and NVM?
thanks
Hi Sirs
thanks
Hi Logan,
TPS53641 has build-in non-volatile memory (NVM) and PMBus interface. The default setting of all the configuration should be detected from pinstrap setting( external resistor selection). However, the users can overwrite the settings via PMBus and stored in NVM after power sequence is complete. This will help board debug and fine tune. Pinstarp and NVM should be used at same time and no priority.
Nancy
