Other Parts Discussed in Thread: LM5020
I am using the LM5020 in an isolated flyback configuration. The output voltage is well regulated over load, but I do not see any variation in duty factor at a given supply voltage. The COMP pin is driven by a MOCD207, and the FB pin is grounded. The scope plots below show trace 1-OUT waveform, 2-CS waveform, 3-COMP pin voltage. Is the duty factor only dependent on supply voltage? The COMP pin varies with no change in duty factor - is this correct operation?
Thank you
