I want to optimize closed loop performance for pfc UCC28060 with regard to phase margin and cross over (0dB) frequency.
Design goal is to reach more than 50 deg of phase margin with cross over at about 10 hz.
output capacity at 660uF, vout at 400 volts and 800 watt load.
Does this IC have feedforward function and what is the internal gain with respect to voltage output beyond the internal transconductance amplifier?
Information is not clearly represented as in UC38050 data and application notes where each block is identified.
Thank you for help,
Vidan Jovanovic
