Hi Sir,
Does any one have the LM5175 QFN layout footprint or dimension ?
LM5175RHFT , I could find it on the datasheet.
thanks.
Mac.
Hi Sir,
thanks.
Mac.
Hi Mac
Interesting - it SHOULD of course be on the DS and I've flagged this omission to our Documentation Control people - thanks for bringing this to our attention.
In any case you can find the drawing for the RHP package (QFN28) at http://www.ti.com/packaging/docs/searchalltipackages.tsp?keyMatch=package%20outline%20drawings&tisearch=Search-EN-Everything
Just in case the link doesn't work here is the .pdf /cfs-file/__key/communityserver-discussions-components-files/196/4061.mpqf251b.pdf
Colin
Hi Colin,
Your attached file do not have pad dimensions. Is there dimensions for the exposed pad?
BR
KC
Hello Kevin
Yes, I see you are correct. I will have to ask someone in the packaging group for these dimensions - I'll get them to as soon as I receive them.
Colin
Hello Kevin
The thermal pad dimensions for the RHF package are 2.55mm x 3.55mm as shown in the document below.
/cfs-file/__key/communityserver-discussions-components-files/196/6763.RHF28-Thermal-Pad.pdf
I'm never quite certain that these links work so please re-post if it doesn't.
Colin
