TPS659037 SMPS efficiency
Other Parts Discussed in Thread: TPS659037
The TPS659037 datasheet shows the efficiency curves for Vin = 3.8V. I need to know the efficiency values for input voltage of 5V. Can you please tell me how I can estimate the efficiency with Vin = 5V? Will the efficiency be better with higher Vin?
Prachi
  • Hello Prachi,
    Efficiency is very similar across input voltage, so you can use the 3.8Vin data to estimate 5Vin condition. Above 500mA load current, they will be within ~0.5% of each other. Below 500mA, they diverge slightly, but will be within a few percent.
    Karl
