BQ34z100-G1 failed to learn
Other Parts Discussed in Thread: BQ34Z100-G1
Hi
I am currently trying to get my Bq34z100-G1 running.
I (hopefully) set all the settings for my system and I tried to start the IT algorithm.
I did all I could find on the web but unfortunately I was not successful.
The voltage and the current are calibrated and read correctly.
After the ITEnable command was sent I discharged it with about 30A (-7444mA in the log).
After this I let it rest for a couple hours and charged it with 15A (3778mA in the log).
The learned status was still 0x04, the SOC jumps while charging (sample 4265 and 8576 in the file) and while discharging (sample 4921 in the file)
The charging curve is a IUI curve (OK our charger is not perfect, the charging line is more like IUU, but this is not the topic here) (www.exide.com/.../Handbook, part 1, edition 6, Feb_ 2012.pdf site 75)
My settings:
24V 105Ah Lead Acid (2x12V Exide GF 12 105 V)
Sense Resistor: 1m
Scaled factor: 4
I attached a charge log, a discharge log and my settings
Can someone help me what I am doing wrong?
Which setting is not correct?
Thanks in advance
* Texas Instruments Data Flash File
* File created Thu May 12 12:45:21 2016
* Device Number 100
* Firmware Version 0.16
* Build Number not available
* Order Number not available
* bqz Device Number 100
* bqz Firmware Version 0.16
* bqz Build Number 17
* Field Order: Class name, Subclass name, Parameter name, Parameter Value, Display Units
Configuration,Safety,OT Chg,60.0,1degC
Configuration,Safety,OT Chg Time,2,Seconds
Configuration,Safety,OT Chg Recovery,55.0,1degC
Configuration,Safety,OT Dsg,60.0,1degC
Configuration,Safety,OT Dsg Time,2,Seconds
Configuration,Safety,OT Dsg Recovery,55.0,1degC
Configuration,Charge Inhibit Cfg,Chg Inhibit Temp Low,0,1degC
Configuration,Charge Inhibit Cfg,Chg Inhibit Temp High,55.0,1degC
Configuration,Charge Inhibit Cfg,Temp Hys,5.0,1degC
Configuration,Charge,Suspend Low Temp,-5.0,1degC
Configuration,Charge,Suspend High Temp,75.0,1degC
Configuration,Charge,Pb EFF Efficiency,100,%
Configuration,Charge,Pb Temp Comp,24.960,%
Configuration,Charge,Pb Drop Off Percent,96,%
Configuration,Charge,Pb Reduction Rate,10.000,%
Configuration,Charge Termination,Taper Current,250,mAmp
Configuration,Charge Termination,Min Taper Capacity,1,mAmpHr
Configuration,Charge Termination,Cell Taper Voltage,100,mVolt
Configuration,Charge Termination,Current Taper Window,30,Seconds
Configuration,Charge Termination,TCA Set %,-1,Percent
Configuration,Charge Termination,TCA Clear %,95,Percent
Configuration,Charge Termination,FC Set %,-1,Percent
Configuration,Charge Termination,FC Clear %,98,Percent
Configuration,Charge Termination,DODatEOC Delta T,10.0,1degC
Configuration,Charge Termination,NiMH Delta Temp,3.0,1degC
Configuration,Charge Termination,NiMH Delta Temp Time,180,Seconds
Configuration,Charge Termination,NiMH Hold Off  Time,100,Seconds
Configuration,Charge Termination,NiMH Hold Off Current,240,mAmp
Configuration,Charge Termination,NiMH Hold Off  Temp,25.0,1degC
Configuration,Charge Termination,NiMH Cell Negative Delta Volt,17,mVolt
Configuration,Charge Termination,NiMH Cell Negative Delta Time,16,Seconds
Configuration,Charge Termination,NiMH Cell Neg Delta Qual Volt,4200,mVolt
Configuration,Data,Manufacture Date,2016-3-21,Day + Mo*32 + (Yr -1980)*256
Configuration,Data,Serial Number,0001,hex
Configuration,Data,Cycle Count,3,Count
Configuration,Data,CC Threshold,15000,mAmpHr
Configuration,Data,Max Error Limit,100,%
Configuration,Data,Design Capacity,26500,MilliAmpHour
Configuration,Data,Design Energy,5400,MilliWattHour
Configuration,Data,SOH Load I,-400,MilliAmp
Configuration,Data,Cell Charge Voltage T1-T2,2600,mV
Configuration,Data,Cell Charge Voltage T2-T3,2600,mV
Configuration,Data,Cell Charge Voltage T3-T4,2600,mV
Configuration,Data,Charge Current T1-T2,10,Percent
Configuration,Data,Charge Current  T2-T3,20,Percent
Configuration,Data,Charge Current  T3-T4,20,Percent
Configuration,Data,JEITA T1,0,degC
Configuration,Data,JEITA T2,10,degC
Configuration,Data,JEITA T3,45,degC
Configuration,Data,JEITA T4,55,degC
Configuration,Data,Design Energy Scale,4,Number
Configuration,Data,Device Name,bq34z100-G1,-
Configuration,Data,Manufacturer Name,Wetrok,-
Configuration,Data,Device Chemistry,Pb,-
Configuration,Discharge,SOC1 Set Threshold,1000,mAh
Configuration,Discharge,SOC1 Clear Threshold,1100,mAh
Configuration,Discharge,SOCF Set Threshold,500,mAh
Configuration,Discharge,SOCF Clear Threshold,700,mAh
Configuration,Discharge,Cell BL Set Volt Threshold,1850,mVolt
Configuration,Discharge,Cell BL Set Volt Time,2,Seconds
Configuration,Discharge,Cell BL Clear Volt Threshold,1900,mVolt
Configuration,Discharge,Cell BH Set Volt Threshold,2650,mVolt
Configuration,Discharge,Cell BH Volt Time,2,Seconds
Configuration,Discharge,Cell BH  Clear Volt Threshold,2500,mVolt
Configuration,Discharge,Cycle Delta,0.05,%
Configuration,Manufacturer Data,Pack Lot Code,0000,hex
Configuration,Manufacturer Data,PCB Lot Code,0000,hex
Configuration,Manufacturer Data,Firmware Version,0000,hex
Configuration,Manufacturer Data,Hardware Revision,0000,hex
Configuration,Manufacturer Data,Cell Revision,0000,hex
Configuration,Manufacturer Data,DF Config Version,0000,hex
Configuration,Lifetime Data,Lifetime Max Temp,30.0,1degC
Configuration,Lifetime Data,Lifetime Min Temp,20.0,1degC
Configuration,Lifetime Data,Lifetime Max Chg Current,0,mAmp
Configuration,Lifetime Data,Lifetime Max Dsg Current,0,mA
Configuration,Lifetime Data,Lifetime Max Pack Voltage,160,20mV
Configuration,Lifetime Data,Lifetime Min Pack Voltage,175,20mV
Configuration,Lifetime Temp Samples,LT Flash Cnt,0,Count
Configuration,Registers,Pack Configuration,09c1,flags
Configuration,Registers,Pack Configuration B,a1,flags
Configuration,Registers,Pack Configuration C,3f,flags
Configuration,Registers,LED_Comm Configuration,00,flags
Configuration,Registers,Alert Configuration,3000,flags
Configuration,Registers,Number of series cell,12,num
Configuration,Lifetime Resolution,LT Temp Res,1.0,1degC
Configuration,Lifetime Resolution,LT Cur Res,100,mA
Configuration,Lifetime Resolution,LT V Res,1,20mV
Configuration,Lifetime Resolution,LT Update Time,60,Seconds
Configuration,LED Display,LED Hold Time,4,Num
Configuration,Power,Flash Update OK Cell Volt,1000,mVolt
Configuration,Power,Sleep Current,10,mAmp
Configuration,Power,FS Wait,0,Seconds
System Data,Manufacturer Info,Block A 0,00,hex
System Data,Manufacturer Info,Block A 1,00,hex
System Data,Manufacturer Info,Block A 2,00,hex
System Data,Manufacturer Info,Block A 3,00,hex
System Data,Manufacturer Info,Block A 4,00,hex
System Data,Manufacturer Info,Block A 5,00,hex
System Data,Manufacturer Info,Block A 6,00,hex
System Data,Manufacturer Info,Block A 7,00,hex
System Data,Manufacturer Info,Block A 8,00,hex
System Data,Manufacturer Info,Block A 9,00,hex
System Data,Manufacturer Info,Block A 10,00,hex
System Data,Manufacturer Info,Block A 11,00,hex
System Data,Manufacturer Info,Block A 12,00,hex
System Data,Manufacturer Info,Block A 13,00,hex
System Data,Manufacturer Info,Block A 14,00,hex
System Data,Manufacturer Info,Block A 15,00,hex
System Data,Manufacturer Info,Block A 16,00,hex
System Data,Manufacturer Info,Block A 17,00,hex
System Data,Manufacturer Info,Block A 18,00,hex
System Data,Manufacturer Info,Block A 19,00,hex
System Data,Manufacturer Info,Block A 20,00,hex
System Data,Manufacturer Info,Block A 21,00,hex
System Data,Manufacturer Info,Block A 22,00,hex
System Data,Manufacturer Info,Block A 23,00,hex
System Data,Manufacturer Info,Block A 24,00,hex
System Data,Manufacturer Info,Block A 25,00,hex
System Data,Manufacturer Info,Block A 26,00,hex
System Data,Manufacturer Info,Block A 27,00,hex
System Data,Manufacturer Info,Block A 28,00,hex
System Data,Manufacturer Info,Block A 29,00,hex
System Data,Manufacturer Info,Block A 30,00,hex
System Data,Manufacturer Info,Block A 31,00,hex
Gas Gauging,IT Cfg,Load Select,3,Number
Gas Gauging,IT Cfg,Load Mode,0,Number
Gas Gauging,IT Cfg,Res Current,10,mAmp
Gas Gauging,IT Cfg,Max Res Factor,50,num
Gas Gauging,IT Cfg,Min Res Factor,1,num
Gas Gauging,IT Cfg,Ra Filter,500,num
Gas Gauging,IT Cfg,Min PassedChg NiMH-LA 1st Qmax,50,%
Gas Gauging,IT Cfg,Maximum Qmax Change,100,%
Gas Gauging,IT Cfg,Cell Terminate Voltage,1700,mVolt
Gas Gauging,IT Cfg,Cell Term V Delta,100,mVolt
Gas Gauging,IT Cfg,ResRelax Time,500,Seconds
Gas Gauging,IT Cfg,User Rate-mA,0,MilliAmp
Gas Gauging,IT Cfg,User Rate-Pwr,0,mW/cW
Gas Gauging,IT Cfg,Reserve Cap-mAh,0,MilliAmpHour
Gas Gauging,IT Cfg,Reserve Energy,0,mWh/cWh
Gas Gauging,IT Cfg,Max Scale Back Grid,4,num
Gas Gauging,IT Cfg,Cell Min DeltaV,0,mVolt
Gas Gauging,IT Cfg,Ra Max Delta,15,%
Gas Gauging,IT Cfg,Design Resistance,42,mOhms
Gas Gauging,IT Cfg,Reference Grid,4,-
Gas Gauging,IT Cfg,Qmax Max Delta %,10,mAmpHour
Gas Gauging,IT Cfg,Max Res Scale,32000,Num
Gas Gauging,IT Cfg,Min Res Scale,1,Num
Gas Gauging,IT Cfg,Fast Scale Start SOC,10,%
Gas Gauging,IT Cfg,Charge Hys V Shift,40,mVolt
Gas Gauging,IT Cfg,Smooth Relax Time,1000,s
Gas Gauging,Current Thresholds,Dsg Current Threshold,60,mAmp
Gas Gauging,Current Thresholds,Chg Current Threshold,50,mAmp
Gas Gauging,Current Thresholds,Quit Current,10,mAmp
Gas Gauging,Current Thresholds,Dsg Relax Time,60,Seconds
Gas Gauging,Current Thresholds,Chg Relax Time,60,Seconds
Gas Gauging,Current Thresholds,Cell Max IR Correct,400,mV
Gas Gauging,State,Qmax Cell 0,26500,mAmpHr
Gas Gauging,State,Cycle Count,0,num
Gas Gauging,State,Update Status,00,num
Gas Gauging,State,Cell V at Chg Term,2600,mVolt
Gas Gauging,State,Avg I Last Run,-299,mAmp
Gas Gauging,State,Avg P Last Run,-1131,MilliWattHour
Gas Gauging,State,Cell Delta Voltage,2,mVolt
Gas Gauging,State,T Rise,20,Num
Gas Gauging,State,T Time Constant,1000,Num
Ra Tables,Ra0 Table,Ra Flag,ff55,Hex
Ra Tables,Ra0 Table,Ra 0,34,Num
Ra Tables,Ra0 Table,Ra 1,31,Num
Ra Tables,Ra0 Table,Ra 2,28,Num
Ra Tables,Ra0 Table,Ra 3,24,Num
Ra Tables,Ra0 Table,Ra 4,23,Num
Ra Tables,Ra0 Table,Ra 5,23,Num
Ra Tables,Ra0 Table,Ra 6,23,Num
Ra Tables,Ra0 Table,Ra 7,25,Num
Ra Tables,Ra0 Table,Ra 8,27,Num
Ra Tables,Ra0 Table,Ra 9,30,Num
Ra Tables,Ra0 Table,Ra 10,35,Num
Ra Tables,Ra0 Table,Ra 11,45,Num
Ra Tables,Ra0 Table,Ra 12,121,Num
Ra Tables,Ra0 Table,Ra 13,268,Num
Ra Tables,Ra0 Table,Ra 14,429,Num
Ra Tables,Ra0x Table,Ra Flag,ffff,Hex
Ra Tables,Ra0x Table,Ra 0,34,Num
Ra Tables,Ra0x Table,Ra 1,31,Num
Ra Tables,Ra0x Table,Ra 2,28,Num
Ra Tables,Ra0x Table,Ra 3,24,Num
Ra Tables,Ra0x Table,Ra 4,23,Num
Ra Tables,Ra0x Table,Ra 5,23,Num
Ra Tables,Ra0x Table,Ra 6,23,Num
Ra Tables,Ra0x Table,Ra 7,25,Num
Ra Tables,Ra0x Table,Ra 8,27,Num
Ra Tables,Ra0x Table,Ra 9,30,Num
Ra Tables,Ra0x Table,Ra 10,35,Num
Ra Tables,Ra0x Table,Ra 11,45,Num
Ra Tables,Ra0x Table,Ra 12,121,Num
Ra Tables,Ra0x Table,Ra 13,268,Num
Ra Tables,Ra0x Table,Ra 14,429,Num
Calibration,Data,CC Gain,4.086,mohm
Calibration,Data,CC Delta,4.079,mohm
Calibration,Data,CC Offset,-1264,num
Calibration,Data,Board Offset,20,num
Calibration,Data,Int Temp Offset,0,degC
Calibration,Data,Ext Temp Offset,0,degC
Calibration,Data,Voltage Divider,35053,mVolt
Calibration,Current,Deadband,5,mAmp
Security,Codes,Sealed to Unsealed,36720414,hex
Security,Codes,Unsealed to Full,ffffffff,hex
Security,Codes,Authen Key3,01234567,hex
Security,Codes,Authen Key2,89abcdef,hex
Security,Codes,Authen Key1,fedcba98,hex
Security,Codes,Authen Key0,76543210,hex
Discharge.txt
5008.Charge.txt
