Hello , I'm in the development department , I have a new task to design a power supply that meets the following: input 85-250 VAC output 24VDC 5VDC 3A and 2A. I could recommend some device and application for this ?.
best regards!!
best regards!!
Jesus
Thanks for your question. Since you have two higher power outputs that both need to be regulated I recommend using an SSR Flyback controller. We recommend UCC28600 or LM5023 for this power level.
If you'd like to learn more about how to desgin the converter, the Isolated Flyback Designs in the TI Power Supply Design Seminar is a great place to start off.
Eric
