Other Parts Discussed in Thread: TPS659037
As per the expected power down sequence for the AM572x processor, the 1.8V core supplies should go down after the PHY supplies. However, as per the ACT2OFF sequence of the TPS659037 PMIC, the 1.8V core supplies (SMPS supplies) go down before the PHY supplies (LDO3, LDO4). Please let me know why is this sequence different and if it is a cause of concern.
In the ACT2SLP sequence, the order is as expected. Can you also tell me why this different is present between the ACT2OFF and ACT2SLP sequences?
Prachi
