TPS65400 Disabling one channel without a fault being reported
While I have the 4th channel enable pin strapped low and have tried to save "Operation (01h)" to "immediate off" I find the PI-Commander user interface still shows the 4th supply PGOOD and Status Byte are RED as well as . I've adjusted the mask bits but they don;t seem to have an effect. on the status byte.
Is the RED just a false indicator or is there a way to truly disable and mask off a supply channel?
