Hi, My customer has question about LP8552. Could you help us?
Q: How much is maximum value of minimum PWM pulse on-time at the over temperature range? *typical value is 1usec.
tateo
tateo
I'm sorry for the long delay in my reply.
My customer considers to use PWM Dimming frequency is up to 20kH and minimum On-Time is 2usec.
So they has concern about variation of minimum PWM pulse on-time.
tateo
Thank you for your support.
My customer has one more question.
- My customer wants to use L=4.7uH or 3.3uH under the following conditions.
Vin=5~21V
Vout=36V
Iout=20mA/ch
fsw=1.25MHz
Is there any concerns about this usage?
They has concern about the stability.
tateo
Thank you for your reply.
My customer considers to use DFE252010F-4R7M.
Could you tell us the concern if inductor value is less than recommended value?
tateo
They can use ~10uF. They should use lower than 1mm height following parts.
So they will use 4.7uF in several parallel.
If they want to run stability analysis, could you provide EVM or simulate stability?
tateo
