BQ34Z110 failed to update the battery State Of Charge ( SOC ) during charging and discharging cycle
Other Parts Discussed in Thread: BQ34Z110
Hi , Thank for the support and sharing the experience.
Battery Spec:   Lead-lead dioxide battery is 12V, 5 Ah . kindly check the  battery datasheet  attached here.
Battery Charger : The charger controls the charging current as well as the charging voltage to safely and efficiently charge the battery. kindly check the                                                  battery charging profile attached here.
 Battery Discharging Cycle:
              Battery is connected to the load ( System : keyboard,display,analog acquisition, 3V regulators  5V regulators ,9V switching regulators ) and the discharge     current is 640mA apporximately. [ SOC failed even while rapid change in the discharge current ( Max current 14A ) ] .
Battery Charging Cycle:
             Battery is charged at maximum current of 1.2A. ( kindly check the  battery charging profile attached here.)
Observation :
  1.       During discharging the battery, state of charge is not update correctly ( ex. System shall switch off  if battery voltage is 11.2V but SOC is 96% at 11.2V ) .
  2.       While start charging the drained battery( 11.2V ), SOC is updated as above 45%
Why the BQ34Z110 fail to provide correct State Of Charge?
Do any design recommendations are  available to avoid SOC failure?
Kindly check the attached information and share the suggestions.
Golden Image
[Header]
bq EVSW Version = 0.9.90
DeviceName = bq34z110 v0.04
Time = 06-05-2016 09:43:40
[Safety(Configuration)]
OT Chg = 55.0
OT Chg Time = 2
OT Chg Recovery = 50.0
OT Dsg = 60.0
OT Dsg Time = 2
OT Dsg Recovery = 55.0
[Charge Inhibit Cfg(Configuration)]
Chg Inhibit Temp Low = 0.0
Chg Inhibit Temp High = 55.0
Temp Hys = 5.0
[Charge(Configuration)]
Suspend Low Temp = -5.0
Suspend High Temp = 55.0
Chg Eff = 100
Chg Eff Temp Comp = 25
Chg Eff Drop Off % = 96
Chg Eff Reduction Rate = 10
Maintenance Current = 0
[Charge Termination(Configuration)]
Taper Current = 143
Min Taper Capacity = 25
Cell Taper Voltage = 100
Current Taper Window = 40
TCA Set % = 99
TCA Clear % = 95
FC Set % = -1
FC Clear % = 98
DODatEOC Delta T = 10.0
[Data(Configuration)]
Rem Cap Alarm = 100
Design Cell Voltage = 2000
Initial Standby = -10
Initial MaxLoad = -500
Manuf Date = 06-May-2016
Ser. Num. = 0001
Cycle Count = 66
CC Threshold = 900
Design Cell Capacity = 5000
Design Cell Energy = 11750
SOH Load I = -400
TDD SOH Percent = 90
Cell Charge Voltage T1-T2 = 2250
Cell Charge Voltage T2-T3 = 2450
Cell Charge Voltage T3-T4 = 2350
Charge Current T1-T2 = 10
Charge Current T2-T3 = 50
Charge Current T3-T4 = 30
JEITA T1 = 0
JEITA T2 = 10
JEITA T3 = 45
JEITA T4 = 55
ISD Current = 10
ISD I Filter = 127
Min ISD Time = 7
Design Energy Scale = 1
Device Name = bq34z110
Manufacturer Name = Texas Inst.
Device Chemistry = PbA
[Discharge(Configuration)]
SOC1 Set Threshold = 150
SOC1 Clear Threshold = 175
SOCF Set Threshold = 75
SOCF Clear Threshold = 100
Cell BL Set Volt Threshold = 1750
Cell BL Set Volt Time = 2
Cell BL Clear Volt Threshold = 1800
Cell BH Set Volt Threshold = 2450
Cell BH Volt Time = 2
Cell BH Clear Volt Threshold = 2400
[Manufacturer Data(Configuration)]
Pack Lot Code = 0000
PCB Lot Code = 0000
Firmware Version = 0000
Hardware Revision = 0000
Cell Revision = 0000
DF Config Version = 0000
[Integrity Data(Configuration)]
Static Chem DF Checksum = 0000
[Lifetime Data(Configuration)]
Lifetime Max Temp = 64.5
Lifetime Min Temp = 20.0
Lifetime Max Chg Current = 2904
Lifetime Max Dsg Current = -11630
Lifetime Max Pack Voltage = 65530
Lifetime Min Pack Voltage = 0
[Lifetime Temp Samples(Configuration)]
LT Flash Cnt = 48
[Registers(Configuration)]
Pack Configuration = 0971
Pack Configuration B = FE
Pack Configuration C = 30
LED_Comm Configuration = 00
Alert Configuration = 0000
Number of series cell = 6
[Lifetime Resolution(Configuration)]
LT Temp Res = 1.0
LT Cur Res = 100
LT V Res = 25
LT Update Time = 60
[LED Display(Configuration)]
LED Hold Time = 4
[Power(Configuration)]
Flash Update OK Cell Volt = 1000
Sleep Current = 10
FS Wait = 0
[Manufacturer Info(System Data)]
Block A 0 = 00
Block A 1 = 00
Block A 2 = 00
Block A 3 = 00
Block A 4 = 00
Block A 5 = 00
Block A 6 = 00
Block A 7 = 00
Block A 8 = 00
Block A 9 = 00
Block A 10 = 00
Block A 11 = 00
Block A 12 = 00
Block A 13 = 00
Block A 14 = 00
Block A 15 = 00
Block A 16 = 00
Block A 17 = 00
Block A 18 = 00
Block A 19 = 00
Block A 20 = 00
Block A 21 = 00
Block A 22 = 00
Block A 23 = 00
Block A 24 = 00
Block A 25 = 00
Block A 26 = 00
Block A 27 = 00
Block A 28 = 00
Block A 29 = 00
Block A 30 = 00
Block A 31 = 00
[IT Cfg(Gas Gauging)]
Load Select = 1
Load Mode = 2
Max Res Factor = 15
Min Res Factor = 3
Ra Filter = 500
Fast Qmax Start DOD % = 92
Fast Qmax End DOD % = 96
Fast Qmax Start Volt Delta = 100
Cell Terminate Voltage = 1750
Cell Term V Delta = 25
ResRelax Time = 200
User Rate-mA = 0
User Rate-Pwr = 0
Reserve Cap-mAh = 0
Reserve Energy = 0
Max Scale Back Grid = 4
Cell Max DeltaV = 100
Cell Min DeltaV = 0
Max Sim Rate = 2
Min Sim Rate = 20
Ra Max Delta = 44
Qmax Max Delta % = 5
Cell DeltaV Max Delta = 10
Fast Scale Start SOC = 10
Charge Hys V Shift = 40
[Current Thresholds(Gas Gauging)]
Dsg Current Threshold = 60
Chg Current Threshold = 75
Quit Current = 40
Dsg Relax Time = 60
Chg Relax Time = 60
Quit Relax Time = 1
Cell Max IR Correct = 400
[State(Gas Gauging)]
Qmax Cell 0 = 5000
Cycle Count = 61
Update Status = 06
Cell V at Chg Term = 2357
Avg I Last Run = -299
Avg P Last Run = -1131
Cell Delta Voltage = 2
T Rise = 20
T Time Constant = 1000
[OCVa Table(OCV Table)]
Chem ID = 0800
[R_a0(Ra Table)]
Cell0 R_a flag = FF55
Cell0 R_a 0 = 83
Cell0 R_a 1 = 66
Cell0 R_a 2 = 56
Cell0 R_a 3 = 51
Cell0 R_a 4 = 47
Cell0 R_a 5 = 47
Cell0 R_a 6 = 49
Cell0 R_a 7 = 56
Cell0 R_a 8 = 59
Cell0 R_a 9 = 64
Cell0 R_a 10 = 72
Cell0 R_a 11 = 83
Cell0 R_a 12 = 150
Cell0 R_a 13 = 267
Cell0 R_a 14 = 275
[R_a0x(Ra Table)]
xCell0 R_a flag = FFFF
xCell0 R_a 0 = 83
xCell0 R_a 1 = 66
xCell0 R_a 2 = 56
xCell0 R_a 3 = 51
xCell0 R_a 4 = 47
xCell0 R_a 5 = 47
xCell0 R_a 6 = 49
xCell0 R_a 7 = 56
xCell0 R_a 8 = 59
xCell0 R_a 9 = 64
xCell0 R_a 10 = 72
xCell0 R_a 11 = 83
xCell0 R_a 12 = 150
xCell0 R_a 13 = 267
xCell0 R_a 14 = 275
[Data(Calibration)]
CC Gain = 10.674
CC Delta = 10.653
CC Offset = -0.69
Board Offset = -0.45
Int Temp Offset = 0.0
Ext Temp Offset = 0.0
Voltage Divider = 16041
[Current(Calibration)]
Deadband = 5
[Codes(Security)]
Sealed to Unsealed = 36720414
Unsealed to Full = FFFFFFFF
Authen Key3 = 01234567
Authen Key2 = 89ABCDEF
Authen Key1 = FEDCBA98
Authen Key0 = 76543210
Battery Datasheet
CP1250H.pdf
Battery charging profile
Battery charging profile.txt
Thank you
