Could someone advise what tools can automatically generate gold data flash image for bq27510g3, automatically complete learning cycles, e.g. BQ27GDK000EVM and bqstudio?
Yunfa
We recommend that you use bqStudio, which is the newer software for gauges. A manual learning cycle can be done by following the steps under "How a Learning Cycle Works" in the document referenced in my previous comment. To set the charge and discharge rates in bqStudio, you will need to click the GDK button and use the Charge Control or Discharge control options under the manual control tab.
Sam
Thanks Sam,
I could not find GDK button in bqStudio, neither learning cycle wizard similar as bqEasy in bqEN. I am using EV2300 interface board. That will be great if you can point me application note for using bqStudio to complete learning cycle.
Here is the screenshot of bqStudio I saw when I tried.
Hi Yunfa,
I believe I initially misinterpreted your question. You will need a GDK to charge and discharge the battery using the gauge that is connected to the GDK. You will be able to perform a learning cycle using the GDK in your setup.
Sam
