Other Parts Discussed in Thread: UCC28950
Page 61 of the UCC28950 data sheet (SLUSA16C) shows a schematic of a daughter card. There are two resistors shown (R5 and R26) that are not populated that I am uncertain of their purpose. For R5, it would appear that this would serve as a voltage divider for the COMP pin. Why would you need this? R26 would seem to allow the ADEL and ADELEF pins to be tied to the CS pin. Again, would this ever be beneficial? I am assuming that if you did populate R26 that both R21 and R23 would then be removed from the circuit. Is that correct? Or would R23 remain in the circuit therefore tying the DCM voltage divider to CS (again not sure why this would be done).
Bill
