Bq25121 sample code
Other Parts Discussed in Thread: BQ25121, BQ25120
Dear TI expert;
 Do you have the BQ25121 sample code which can use I2C to control the the BQ25121 charging process?  Thank you very much.
  • FanYang,
    Here is a sample code for accessing the BQ25120.
     * BQ25120 Battery Charger Driver
     * Copyright (C) 2015,  Texas Instruments Corporation
     * License TBD from SRAS
    #include <linux/err.h>
    #include <linux/kernel.h>
    #include <linux/module.h>
    #include <linux/init.h>
    #include <linux/interrupt.h>
    #include <linux/i2c.h>
    #include <linux/power_supply.h>
    #include <linux/regmap.h>
    /* Registers */
    #define BQ25120_STATUS_SHIPMODE_REG		0x00
    #define BQ25120_FAULTS_FAULTMASKS_REG		0x01
    #define BQ25120_TSCONTROL_STATUS_REG		0x02
    #define BQ25120_FASTCHARGE_CTL_REG		0x03
    #define BQ25120_CHARGETERM_I2CADDR_REG		0x04
    #define BQ25120_BATT_VOLTAGE_CTL_REG		0x05
    #define BQ25120_SYSTEM_VOUT_CTL_REG		0x06
    #define BQ25120_LOADSW_LDO_CTL_REG		0x07
    #define BQ25120_PUSH_BTN_CTL_REG		0x08
    #define BQ25120_ILIMIT_UVLO_CTL_REG		0x09
    #define BQ25120_BATT_VOLT_MONITOR_REG		0x0A
    #define BQ25120_VIN_DPM_TIMER_REG		0x0B
    /* Status and ShipMode Control Register (0x0) */
    #define BQ25120_STAT		(BIT(7) | BIT(6))
    #define BQ25120_STAT_SHIFT	0x06
    #define BQ25120_STAT_MASK	0x03
    #define BQ25120_EN_SHIPMODE	BIT(5)
    #define BQ25120_RESET		BIT(4)
    #define BQ25120_TIMER		BIT(3)
    #define BQ25120_VINDPM_STAT	BIT(2)
    #define BQ25120_NOT_CD_STAT	BIT(1)
    #define BQ25120_SYS_EN_STAT	BIT(0)
    /* Faults and Fault Masks Register (Ox1) */
    #define BQ25120_VIN_OV		BIT(7)
    #define BQ25120_VIN_UV		BIT(6)
    #define BQ25120_BAT_UVLO	BIT(5)
    #define BQ25120_BAT_OCP		BIT(4)
    #define BQ25120_FAULTS		(BIT(7) | BIT(6) | BIT(5) | BIT(4))
    #define BQ25120_FAULTS_SHIFT    0x04
    #define BQ25120_FAULTS_MASK	0x0F
    #define BQ25120_VIN_OV_M	BIT(3)
    #define BQ25120_VIN_OV_M_SHIFT	0x03
    #define BQ25120_VIN_OV_M_MASK	0x01
    #define BQ25120_VIN_UV_M	BIT(2)
    #define BQ25120_VIN_UV_M_SHIFT	0x02
    #define BQ25120_VIN_UV_M_MASK	0x01
    #define BQ25120_BAT_UVLO_M	BIT(1)
    #define BQ25120_BAT_UVLO_M_SHIFT	0x01
    #define BQ25120_BAT_UVLO_M_MASK	0x01
    #define BQ25120_BAT_OCP_M	BIT(0)
    #define BQ25120_BAT_OCP_M_SHIFT	0x0
    #define BQ25120_BAT_OCP_M_MASK	0x01
    /* TS Control and Status Mask Register (0x2) */
    #define BQ25120_TS_EN		BIT(7)
    #define BQ25120_TS_FAULT	(BIT(6) | BIT(5))
    #define BQ25120_TS_FAULT_SHIFT  0x05
    #define BQ25120_TS_FAULT_MASK	0X03
    #define BQ25120_TS_FAULT_OPEN	BIT(4)
    #define BQ25120_EN_INT		BIT(3)
    #define BQ25120_WAKE_M		BIT(2)
    #define BQ25120_WAKE_M_SHIFT	0x02
    #define BQ25120_WAKE_M_MASK	0x01
    #define BQ25120_RESET_M		BIT(1)
    #define BQ25120_RESET_SHIFT	0x01
    #define BQ25120_RESET_MASK	0x01
    #define BQ25120_TIMER_M		BIT(0)
    #define BQ25120_TIMER_M_SHIFT	0
    #define BQ25120_TIMER_M_MASK	0x01
    /* Fast Charge Control Register (0x03) */
    #define BQ25120_ICHRG_RANGE	BIT(7)
    #define BQ25120_ICHARG		(BIT(6) | BIT(5) | BIT(4) | BIT(3) | BIT(2))
    #define BQ25120_ICHARG_SHIFT	0x02
    #define BQ25120_ICHARG_MASK	0x1F
    #define BQ25120_CE		BIT(1)
    #define BQ25120_HZ_MODE		BIT(0)
    /* Termination/Pre-Charge and I2C Address Register (0x4) */
    #define BQ25120_IPRETERM_RANGE	BIT(7)
    #define BQ25120_IPRETERM	(BIT(6) | BIT(5) | BIT(4) | BIT(3) | BIT(2))
    #define BQ25120_IPRETERM_SHIFT  0x02
    #define BQ25120_IPRETERM_MASK   0x1F
    #define BQ25120_TE		BIT(1)
    // Bit 0 Reserved
    /* Battery Voltage Control Register (0x05) */
    #define BQ25120_VBREG		(BIT(7) | BIT(6) | BIT(5) | BIT(4) | BIT(3) | BIT(2) | BIT(1))
    #define BQ25120_VBREG_SHIFT	0x1
    #define BQ25120_VBREG_MASK	0x7F
    // Bit 0 Reserved
    /* SYS VOUT Control Register (0x06) */
    #define BQ25120_EN_SYS_OUT	BIT(7)
    #define BQ25120_SYS_SEL		(BIT(6) | BIT(5))
    #define BQ25120_SYS_SEL_SHIFT	0x4
    #define BQ25120_SYS_MASK	0x3
    #define BQ25120_SYS_VOUT	(BIT(4) | BIT(3) | BIT(2) | BIT(1))
    #define BQ25120_SYS_VOUT_SHIFT	0x01
    #define BQ25120_SYS_VOUT_MASK	0x0F
    //Bit 0 Reserved
    /* Load Switch and LDO Control Register (0x07) */
    #define BQ25120_EN_LS_LDO	BIT(7)
    #define BQ25120_LS_LDO		(BIT(6) | BIT(5) | BIT(4) | BIT(3) | BIT(2))
    #define BQ25120_LS_LDO_SHIFT	0x2
    #define BQ25120_LS_LDO_MASK	0x1F
    //Bit 1 Reserved
    #define BQ25120_MRRESET_VIN	BIT(0)
    /* Pushbutton Control Register (0x08) */
    #define BQ25120_MRWAKE1	    	BIT(7)
    #define BQ25120_MRWAKE2		BIT(6)
    #define BQ25120_MRREC		BIT(5)
    #define BQ25120_MRRESET		(BIT(4) | BIT(3))
    #define BQ25120_MRRESET_SHIFT	0x03
    #define BQ25120_MRRESET_MASK	0x03
    #define BQ25120_PGB_MRS		BIT(2)
    #define BQ25120_WAKE1		BIT(1)
    #define BQ25120_WAKE2		BIT(0)
    /* ILIM and Battery UVLO Control Register (0x09) */
    #define BQ25120_RESET_REG	BIT(7)
    //Bit 6 Reserved
    #define BQ25120_INLIM		(BIT(5) | BIT(4) | BIT(3))
    #define BQ25120_INLIM_SHIFT	0x03
    #define BQ25120_INLIM_MASK	0x07
    #define BQ25120_BUVLO		(BIT(2) | BIT(1) | BIT(0))
    #define BQ25120_BUVLO_SHIFT	0x0
    #define BQ25120_BUVLO_MASK	0x7
    /* Voltage Based Battery Monitor Register (0x0A) */
    #define BQ25120_VBMON_READ	BIT(7)
    #define BQ25120_VBMON_RANGE	(BIT(6) | BIT(5))
    #define BQ25120_VBMON_RANGE_SHIFT 0x05
    #define BQ25120_VBMON_RANGE_MASK  0x03
    #define BQ25120_VBMON_TH	(BIT(4) | BIT(3) | BIT(2))
    #define BQ25120_VBMON_TH_SHIFT	0x02
    #define BQ25120_VBMON_TH_MASK	0x07
    //Bit 1 and 0 Reserved
    /* VIN_DPM and Timers Register (0x0B) */
    #define BQ25120_VINDPM_OFF	BIT(7)
    #define BQ25120_VINDPM		(BIT(6) | BIT(5) | BIT(4))
    #define BQ25120_VINDPM_SHIFT	0x04
    #define BQ25120_VINDPM_MASK	0x07
    #define BQ25120_2XTMR_EN	BIT(3)
    #define BQ25120_TMR		(BIT(2) | BIT(1))
    #define BQ25120_TMR_SHIFT	0x01
    #define BQ25120_TMR_MASK	0x03
    #define BQ25120_TMR_DISABLE	0x03
    //Bit 0 Reserved
    #define BQ25120_MAX_CHG_FAULT	8
    static struct reg_default BQ25120_reg_defs[] = {
    	{BQ25120_STATUS_SHIPMODE_REG, 0x01},
    	{BQ25120_FAULTS_FAULTMASKS_REG, 0x00},
    	{BQ25120_TSCONTROL_STATUS_REG, 0x88},
    	{BQ25120_FASTCHARGE_CTL_REG, 0x14},
    	{BQ25120_CHARGETERM_I2CADDR_REG, 0x0E},
    	{BQ25120_BATT_VOLTAGE_CTL_REG, 0x78},
    	{BQ25120_SYSTEM_VOUT_CTL_REG, 0xAA},
    	{BQ25120_LOADSW_LDO_CTL_REG, 0x7C},
    	{BQ25120_PUSH_BTN_CTL_REG, 0x68},
    	{BQ25120_ILIMIT_UVLO_CTL_REG, 0x0A},
    	{BQ25120_BATT_VOLT_MONITOR_REG, 0x00},
    	{BQ25120_VIN_DPM_TIMER_REG, 0x4A},
    enum BQ25120_charge_fault {
    	BQ25120_NORMAL = 0,
    	BQ25120_CH_VIN_OV,
    	BQ25120_CH_VIN_UV,
    	BQ25120_BATTERY_UVLO,
    	BQ25120_BATTERY_OCP,
    enum BQ25120_temp_status {
    	BQ25120_TEMP_NORMAL = 0,
    	BQ25120_TEMP_TNTC,
    	BQ25120_TEMP_TCOOL,
    	BQ25120_TEMP_TWARM,
    //Not used.
    static const char *fault_desc[BQ25120_MAX_CHG_FAULT] = {
    	[BQ25120_NORMAL] = "Normal",
    	[BQ25120_VIN] = "Vin > VovpINPUT",
    	[BQ25120_LOW_SUPPLY_CONNECTED] =
    			"Low Power Supply Connected or Boost Mode Overcurrent",
    	[BQ25120_THERMAL_SHUTDOWN] = "Thermal Shutdown",
    	[BQ25120_BATTERY_TS_FAULT] = "Battery Temperature Fault",
    	[BQ25120_BATTERY_OVP] = "Battery OVP",
    	[BQ25120_NO_BATTERY_CONNECTED] = "No Battery Connected",
    static const char * temp_status_desc[BQ25120_MAX_TEMP_STATUS] = {
    	[BQ25120_TEMP_TNTC] = "TS temp < Tcold or TS temp > Thot",
    	[BQ25120_TEMP_TCOOL] = "Tcool > TS temp or TS temp > Tcold",
    	[BQ25120_TEMP_TWARM] = "Twarm < TS temp or TS temp < Tcold",
     * struct bq25120_charger - bq25120 charger instance
     * @dev: pointer to device
     * @regmap: pointer to driver regmap
     * @mains: power_supply instance for AC/DC power
     * @battery: power_supply instance for battery
     * @mains_online: is AC/DC input connected
     * @charging_enabled: is charging enabled
     * @pdata: pointer to platform data
     * @irq: fault irq number
    struct bq25120_charger {
    	struct device		*dev;
    	struct regmap		*regmap;
    	struct power_supply	mains;
    	struct power_supply	battery;
    	bool			mains_online;
    	bool			usb_online;
    	bool			charging_enabled;
    	bool			vsysoff_enabled;
    	int                     irq; /* IRQ for INT pin */
    	const struct bq25120_charger_platform_data *pdata;
    /* Charge current in mA */
    static const unsigned int cc_tbl[] = {
    	5,
    	6,
    	7,
    	8,
    	9,
    	10,
    	11,
    	12,
    	13,
    	14,
    	15,
    	16,
    	17,
    	18,
    	19,
    	20,
    	21,
    	22,
    	23,
    	24,
    	25,
    	26,
    	27,
    	28,
    	29,
    	30,
    	31,
    	32,
    	33,
    	34,
    	35,
    	40,
    	50,
    	60,
    	70,
    	80,
    	90,
    	100,
    	110,
    	120,
    	130,
    	140,
    	150,
    	160,
    	170,
    	180,
    	190,
    	200,
    	210,
    	220,
    	230,
    	240,
    	250,
    	260,
    	270,
    	280,
    	290,
    	300
    /* Termination current in mA */
    static const unsigned int tc_tbl[] = {
    	1,
    	2,
    	3,
    	4,
    	5,
    	6,
    	7,
    	8,
    	9,
    	10,
    	11,
    	12,
    	13,
    	14,
    	15,
    	16,
    	17,
    	18,
    	19,
    	20,
    	21,
    	22,
    	23,
    	24,
    	25,
    	26,
    	27,
    	28,
    	29,
    	30,
    	31,
    	32,
    	33,
    	34,
    	35,
    	36,
    	37
    /* Input current limit in mA */
    static const unsigned int icl_tbl[] = {
    	50,
    	100,
    	150,
    	200,
    	250,
    	300,
    	350,
    	400
    /* Safety timer time limit in minutes */
    static const unsigned int stl_tbl[] = {
    	30,
    	180,
    	540,
    	0, /* Disable */
    /* Convert current to register value using lookup table */
    static int current_to_hw(const unsigned int *tbl, size_t size, unsigned int val)
    	size_t i;
    	for (i = 0; i < size; i++)
    		if (val < tbl[i])
    			break;
    	return i > 0 ? i - 1 : -EINVAL;
     * bq25120_is_ps_online - returns whether input power source is connected
     * @bq25120: pointer to bq25120 charger instance
     * Returns %true if input power source is connected. Note that this is
     * dependent on what platform has configured for usable power sources.
    static bool bq25120_is_ps_online(struct bq25120_charger *bq25120)
    	return (bq25120->mains_online);
     * bq25120_update_ps_status - refreshes the power source status
     * Function checks whether any power source is connected to the charger and
     * updates internal state accordingly. If there is a change to previous state
     * function returns %1, otherwise %0 and negative errno in case of errror.
    static int bq25120_update_ps_status(struct bq25120_charger *bq25120)
    	bool usb = false;
    	bool dc = false;
    	unsigned int val;
    	int ret;
    	int vinDpm;
    	ret = regmap_read(bq25120->regmap, BQ25120_BATT_VOLT_MONITOR_REG , &val);
    	if (ret < 0)
    		return ret;
    	 * platform data _and_ whether corresponding undervoltage is set.
    	if (bq25120->pdata->use_mains)
    		dc = !( (val >> 7) BQ25120_VINDPM_OFF) );
    	ret = bq25120->mains_online != dc;
    	bq25120->mains_online = dc;
    	return ret;
    enum power_supply_property bq25120_charger_properties[] = {
    	POWER_SUPPLY_PROP_ONLINE,
    	POWER_SUPPLY_PROP_CONSTANT_CHARGE_CURRENT,
    	POWER_SUPPLY_PROP_CONSTANT_CHARGE_VOLTAGE,
     * bq25120_charging_status - returns status of charging
     * Function returns charging status.
     * %0 means ready, %1 charging is in progress,
     * %2charging done and %3 fault.
    static int bq25120_charging_status(struct bq25120_charger *bq25120)
    	unsigned int val;
    	int ret;
    	if (!bq25120_is_ps_online(bq25120))
    		return 0;
    	ret = regmap_read(bq25120->regmap, BQ25120_STATUS_SHIPMODE_REG, &val);
    	if (ret < 0)
    		return 0;
    	return  ((val & BQ25120_STAT_MASK) >> BQ25120_STAT_SHIFT);
    static int bq25120_charging_type(struct bq25120_charger *bq25120)
    	unsigned int val;
    	int ret;
    		return 0;
    	if (ret < 0)
    		return 0;
    	return  ((val >> BQ25120_STAT_SHIFT) & BQ25120_STAT_MASK);
    static int bq25120_timer_suspend(struct bq25120_charger *bq25120)
    	int ret = 0;
    	if (bq25120->pdata->enable_control != BQ25120_CE) {
    		dev_dbg(bq25120->dev, "vsys enable/disable in SW disabled\n");
    		return 0;
    	ret = regmap_update_bits(bq25120->regmap, BQ25120_VIN_DPM_TIMER_REG,
    				 BQ25120_TMR, BQ25120_TMR_DISABLE);
    	if (!ret)
    		dev_err(bq25120->dev, "failed to suspend timer\n");
    	return ret;
    static int bq25120_timer_reset(struct bq25120_charger *bq25120)
    	int ret;
    	unsigned int tmr;
    	/* Reset with previous time value, when fault occur */
    	ret = regmap_read(bq25120->regmap, BQ25120_VIN_DPM_TIMER_REG, &tmr);
    	tmr = (tmr & BQ25120_TMR) >> BQ25120_TMR_SHIFT;
    				 BQ25120_TMR, tmr);
    	if (!ret)
    		dev_err(bq25120->dev, "failed to reset timer\n");
    	return ret;
    static int bq25120_charging_set(struct bq25120_charger *bq25120, bool enable)
    	int ret = 0;
    	if (bq25120->charging_enabled != enable) {
    		ret = regmap_update_bits(bq25120->regmap, BQ25120_FASTCHARGE_CTL_REG,
    					 BQ25120_CE, enable ? 0 : 1);
    		if (!ret)
    			bq25120->charging_enabled = enable;
    	return ret;
    static inline int bq25120_charging_enable(struct bq25120_charger *bq25120)
    	return bq25120_charging_set(bq25120, true);
    static inline int bq25120_charging_disable(struct bq25120_charger *bq25120)
    	return bq25120_charging_set(bq25120, false);
    static int bq25120_start_stop_charging(struct bq25120_charger *bq25120)
    	int ret;
    	 * Depending on whether valid power source is connected or not, we
    	 * disable or enable the charging. We do it manually because it
    	 * depends on how the platform has configured the valid inputs.
    	if (bq25120_is_ps_online(bq25120)) {
    		ret = bq25120_charging_enable(bq25120);
    		if (ret < 0)
    			dev_err(bq25120->dev, "failed to enable charging\n");
    	} else {
    		ret = bq25120_charging_disable(bq25120);
    		if (ret < 0)
    			dev_err(bq25120->dev, "failed to disable charging\n");
    	return ret;
    static int bq25120_set_charge_current(struct bq25120_charger *bq25120)
    	int ret;
    	unsigned int max_chrg_curr = bq25120->pdata->max_charge_current;
    	unsigned int term_curr = bq25120->pdata->termination_current;
    	if (max_chrg_curr) {
    		if (max_chrg_curr > 300) {
    			dev_warn(bq25120->dev, "Platform max charge current %d. \
    				 Set to 300mA for bq25120\n", max_chrg_curr);
    		ret = current_to_hw(cc_tbl, ARRAY_SIZE(cc_tbl), max_chrg_curr);
    		if (ret < 0)
    			return ret;
    					 BQ25120_IPRETERM, ret);
    		if (ret < 0)
    			return ret;
    	if (term_curr) {
    		if (term_curr < 5) {
    			dev_warn(bq25120->dev, "Platform termination current %d. \
    				 Set to 5mA for bq25120\n", term_curr);
    		ret = current_to_hw(tc_tbl, ARRAY_SIZE(tc_tbl), term_curr);
    		if (ret < 0)
    			return ret;
    		if (ret < 0)
    			return ret;
    	return 0;
    static int bq25120_set_current_limits(struct bq25120_charger *bq25120)
    	int ret;
    	if (bq25120->pdata->mains_current_limit) {
    		ret = current_to_hw(icl_tbl, ARRAY_SIZE(icl_tbl),
    				    bq25120->pdata->mains_current_limit);
    		if (ret < 0)
    			return ret;
    		if (ret > 400)
    			dev_warn(bq25120->dev, "Invalid mains input current limit\n");
    		else {
    					 	 BQ25120_INLIM, ret);
    			if (ret < 0)
    				return ret;
    	return 0;
    static int bq25120_set_voltage_limits(struct bq25120_charger *bq25120)
    	int ret;
    	if (bq25120->pdata->max_charge_voltage) {
    		ret = bq25120->pdata->max_charge_voltage;
    		if (ret < 0)
    			return ret;
    					 BQ25120_VBREG, ret);
    		if (ret < 0)
    			return ret;
    	return 0;
    static int bq25120_hw_init(struct bq25120_charger *bq25120)
    	int ret;
    	 * Program the platform specific configuration values to the device
    	 * first.
    	ret = bq25120_set_charge_current(bq25120);
    	if (ret < 0)
    		goto fail;
    	ret = bq25120_set_current_limits(bq25120);
    	if (ret < 0)
    		goto fail;
    	ret = bq25120_set_voltage_limits(bq25120);
    	if (ret < 0)
    		goto fail;
    	ret = bq25120_update_ps_status(bq25120);
    	if (ret < 0)
    		goto fail;
    	ret = bq25120_start_stop_charging(bq25120);
    fail:
    	return ret;
    static irqreturn_t bq25120_interrupt(int irq, void *data)
    	struct bq25120_charger *bq25120 = data;
    	unsigned int irqstat;
    	bool handled = false;
    	int ret;
    	ret = regmap_read(bq25120->regmap, BQ25120_FAULTS_FAULTMASKS_REG,
    			  &irqstat);
    	if (ret < 0) {
    		dev_warn(bq25120->dev, "reading BQ25120_FAULTS_FAULTMASKS_REG failed\n");
    		return IRQ_NONE;
    	irqstat &= 0xF0;  //Mask mask bits
    	 * If we get a fault report the error.
    	switch (irqstat)  {
    	case BQ25120_NORMAL:	/* Normal  - No fault */
    		handled = true;
    		break;
    	case BQ25120_VIN_OV:
    		dev_info(bq25120->dev,"Charger Fault: Vin Over Voltage fault.\n");
    		handled = false;
    		break;
    	case BQ25120_VIN_UV:
    		dev_info(bq25120->dev,"Charger Fault: VIN Under Voltage fault.\n");
    		handled = false;
    		break;
    	case BQ25120_BAT_UVLO:
    			"Battery Fault: BAT_UVLO fault.\n");
    		handled = false;
    		break;
    	case BQ25120_BAT_OCP:
    			"Battery Fault: BAT_OCP fault.\n");
    		handled = false;
    		break;
    	default:
    			"Fault: unknown fault# %d - not handled. \n",
    			 irqstat);
    		handled = false;
    		break;
    	return handled ? IRQ_HANDLED : IRQ_NONE;
    static int bq25120_irq_set(struct bq25120_charger *bq25120, bool enable)
    	int ret;
    	* Enable/disable interrupts for:
    	ret = regmap_update_bits(bq25120->regmap, BQ25120_TSCONTROL_STATUS_REG,
    				 BQ25120_EN_INT, enable ? 1 : 0);
    	if (ret < 0)
    		return ret;
    	return 0;
    static inline int bq25120_irq_enable(struct bq25120_charger *bq25120)
    	return bq25120_irq_set(bq25120, true);
    static inline int bq25120_irq_disable(struct bq25120_charger *bq25120)
    	return bq25120_irq_set(bq25120, false);
    static int bq25120_irq_init(struct bq25120_charger *bq25120, int irq)
    	int ret;
    	if (irq <= 0) {
    		dev_info(bq25120->dev, "invalid irq number: %d\n", irq);
    		goto out;
    			   BQ25120_EN_INT, 1);
    	ret = request_threaded_irq(irq, NULL, bq25120_interrupt,
    				   IRQF_TRIGGER_RISING | IRQF_ONESHOT,
    				   "bq25120_irq", bq25120);
    	if (ret)
    		return ret;
    	bq25120->irq = irq;
    	bq25120_irq_enable(bq25120);
    out:
    	return 0;
    static ssize_t bq25120_show_charger_fault(struct device *dev,
    					  struct device_attribute *attr,
    					  char *buf)
    	unsigned int val;
    	int ret;
    	struct bq25120_charger *bq25120 = dev_get_drvdata(dev);
    	ret = regmap_read(bq25120->regmap, BQ25120_FAULTS_FAULTMASKS_REG, &val);
    	if (ret < 0)
    		return 0;
    	val &= 0xC0;
    	switch (val)
    	    return scnprintf(buf, PAGE_SIZE, "%s\n", "Charge VIN overvoltage fault.");
    	    break;
    	     return scnprintf(buf, PAGE_SIZE, "%s\n", "Charge VIN undervoltage fault.");
    	     break;
    	return 0;
    static ssize_t bq25120_show_temp_fault(struct device *dev,
    				       struct device_attribute *attr, char *buf)
    	unsigned int val;
    	int ret;
    	ret = regmap_read(bq25120->regmap, BQ25120_TSCONTROL_STATUS_REG, &val);
    	if (ret < 0)
    		return 0;
    	val = (val >> BQ25120_TS_FAULT_SHIFT) & BQ25120_TS_FAULT_MASK;
    	return scnprintf(buf, PAGE_SIZE, "%s\n", temp_status_desc[val]);
    static DEVICE_ATTR(charger_fault, S_IRUSR, bq25120_show_charger_fault, NULL);
    static DEVICE_ATTR(temp_fault, S_IRUSR, bq25120_show_temp_fault, NULL);
    static struct attribute *bq25120_charger_attr[] = {
    	&dev_attr_charger_fault.attr,
    	&dev_attr_temp_fault.attr,
    	NULL,
    static const struct attribute_group bq25120_attr_group = {
    	.attrs = bq25120_charger_attr,
     * Returns the constant charge current programmed
     * into the charger in mA.
    static int get_const_charge_current(struct bq25120_charger *bq25120)
    	int ret;
    	unsigned int val, intval;
    		return -ENODATA;
    	ret = regmap_read(bq25120->regmap, bq25120_CHARGE_CURR_TERM_REG, &val);
    	if (ret < 0)
    		return ret;
    	val = (val & bq25120_CHARGE_CURR) >> bq25120_CHARGE_CURR_SHIFT;
    	intval = 500 + val * 100;
    	if (intval >= 3000)
    		intval = 3000; /* set Max as 3A */
    	dev_info(bq25120->dev, "const charge current is %d mA\n", intval);
    	return intval;
     * Returns the constant charge voltage programmed
     * into the charger in mV.
    static int get_const_charge_voltage(struct bq25120_charger *bq25120)
    	int ret;
    	unsigned int val;
    	int intval;
    		return -ENODATA;
    	ret = regmap_read(bq25120->regmap, bq25120_BATTERY_VOLTAGE_REG, &val);
    	if (ret < 0)
    		return ret;
    	val = (val & bq25120_BATTERY_VOLTAGE) >> bq25120_BATTERY_VOLTAGE_SHIFT;
    	intval = 3500 + val * 20;
    	if (intval >= 4440)	/* set MAX as 4.4V */
    		intval = 4440;
    	dev_info(bq25120->dev, "const charge voltage is=%d mV\n", intval);
    	return intval;
    static int bq25120_mains_get_property(struct power_supply *psy,
    				     enum power_supply_property prop,
    				     union power_supply_propval *val)
    		container_of(psy, struct bq25120_charger, mains);
    	int ret;
    	switch (prop) {
    	case POWER_SUPPLY_PROP_ONLINE:
    		val->intval = bq25120->mains_online;
    		break;
    	case POWER_SUPPLY_PROP_CONSTANT_CHARGE_VOLTAGE:
    		ret = get_const_charge_voltage(bq25120);
    		if (ret < 0)
    			return ret;
    		else
    			val->intval = ret;
    		break;
    	case POWER_SUPPLY_PROP_CONSTANT_CHARGE_CURRENT:
    		ret = get_const_charge_current(bq25120);
    		if (ret < 0)
    			return ret;
    		else
    			val->intval = ret;
    		break;
    	default:
    		return -EINVAL;
    	return 0;
    static int bq25120_battery_get_property(struct power_supply *psy,
    			container_of(psy, struct bq25120_charger, battery);
    	const struct bq25120_charger_platform_data *pdata = bq25120->pdata;
    	int ret;
    	if (ret < 0)
    		return ret;
    	switch (prop) {
    	case POWER_SUPPLY_PROP_STATUS:
    		if (!bq25120_is_ps_online(bq25120)) {
    			val->intval = POWER_SUPPLY_STATUS_DISCHARGING;
    			break;
    		switch (bq25120_charging_status(bq25120)) {
    		case 0:
    			break;
    		case 1:
    			val->intval = POWER_SUPPLY_STATUS_CHARGING;
    			break;
    		case 2:
    			val->intval = POWER_SUPPLY_STATUS_FULL;
    			break;
    		case 3:
    			val->intval = POWER_SUPPLY_STATUS_UNKNOWN; /* FAULT */
    			break;
    		break;
    	case POWER_SUPPLY_PROP_CHARGE_TYPE:
    			return -ENODATA;
    		/* We handle charger mode and boost mode.  */
    		switch (bq25120_charging_type(bq25120)) {
    		case 0:
    			val->intval = POWER_SUPPLY_CHARGE_TYPE_TRICKLE;
    			break;
    		case 1:
    			val->intval = POWER_SUPPLY_CHARGE_TYPE_FAST;
    			break;
    		default:
    			val->intval = POWER_SUPPLY_CHARGE_TYPE_NONE;
    			break;
    		break;
    	case POWER_SUPPLY_PROP_TECHNOLOGY:
    		val->intval = pdata->battery_info.technology;
    		break;
    	case POWER_SUPPLY_PROP_VOLTAGE_MIN_DESIGN:
    		val->intval = pdata->battery_info.voltage_min_design;
    		break;
    	case POWER_SUPPLY_PROP_VOLTAGE_MAX_DESIGN:
    		val->intval = pdata->battery_info.voltage_max_design;
    		break;
    	case POWER_SUPPLY_PROP_CHARGE_FULL_DESIGN:
    		val->intval = pdata->battery_info.charge_full_design;
    		break;
    	case POWER_SUPPLY_PROP_MODEL_NAME:
    		val->strval = pdata->battery_info.name;
    		break;
    	default:
    		return -EINVAL;
    	return 0;
    static enum power_supply_property bq25120_battery_properties[] = {
    	POWER_SUPPLY_PROP_STATUS,
    	POWER_SUPPLY_PROP_CHARGE_TYPE,
    	POWER_SUPPLY_PROP_TECHNOLOGY,
    	POWER_SUPPLY_PROP_VOLTAGE_MIN_DESIGN,
    	POWER_SUPPLY_PROP_VOLTAGE_MAX_DESIGN,
    	POWER_SUPPLY_PROP_CHARGE_FULL_DESIGN,
    	POWER_SUPPLY_PROP_MODEL_NAME,
    static int bq25120_power_supply_register(struct bq25120_charger *bq25120)
    	static char *battery[] = { "bq25120-battery" };
    	int ret;
    	if (bq25120->pdata->use_mains) {
    		bq25120->mains.name = "bq25120-mains";
    		bq25120->mains.type = POWER_SUPPLY_TYPE_MAINS;
    		bq25120->mains.get_property = bq25120_mains_get_property;
    		bq25120->mains.properties = bq25120_charger_properties;
    		bq25120->mains.num_properties =
    					ARRAY_SIZE(bq25120_charger_properties);
    		bq25120->mains.supplied_to = battery;
    		bq25120->mains.num_supplicants = ARRAY_SIZE(battery);
    		ret = power_supply_register(bq25120->dev, &bq25120->mains);
    		if (ret < 0)
    			return ret;
    	bq25120->battery.name = "bq25120-battery";
    	bq25120->battery.type = POWER_SUPPLY_TYPE_BATTERY;
    	bq25120->battery.get_property = bq25120_battery_get_property;
    	bq25120->battery.properties = bq25120_battery_properties;
    	bq25120->battery.num_properties =
    				ARRAY_SIZE(bq25120_battery_properties);
    	ret = power_supply_register(bq25120->dev, &bq25120->battery);
    	if (ret < 0) {
    			power_supply_unregister(&bq25120->mains);
    		return ret;
    	return 0;
    static void bq25120_power_supply_unregister(struct bq25120_charger *bq25120)
    	power_supply_unregister(&bq25120->battery);
    	if (bq25120->pdata->use_usb)
    		power_supply_unregister(&bq25120->usb);
    static const struct regmap_config bq25120_regmap = {
    	.reg_bits         = 8,
    	.val_bits         = 8,
    	.max_register     = bq25120_MAX_REGISTER,
    	.reg_defaults     = bq25120_reg_defs,
    	.num_reg_defaults = ARRAY_SIZE(bq25120_reg_defs),
    	.cache_type	  = REGCACHE_RBTREE,
    static int bq25120_probe(struct i2c_client *client,
    			const struct i2c_device_id *id)
    	struct device *dev = &client->dev;
    	struct bq25120_charger *bq25120;
    	int ret;
    	pdata = dev->platform_data;
    	if (!pdata) {
    		printk(KERN_NOTICE "In probe - failed with NO PDATA\n");
    		return -EINVAL;
    	bq25120 = devm_kzalloc(dev, sizeof(*bq25120), GFP_KERNEL);
    	if (!bq25120)
    		return -ENOMEM;
    	bq25120->dev = &client->dev;
    	bq25120->pdata = client->dev.platform_data;
    	i2c_set_clientdata(client, bq25120);
    	bq25120->regmap = devm_regmap_init_i2c(client, &bq25120_regmap);
    	if (IS_ERR(bq25120->regmap))
    		return PTR_ERR(bq25120->regmap);
    	ret = bq25120_hw_init(bq25120);
    	if (ret < 0) {
    		dev_err(dev, "failed to initialize bq25120 device: %d\n", ret);
    		goto err_dev;
    	ret = bq25120_power_supply_register(bq25120);
    	if (ret < 0) {
    		dev_err(dev, "failed to register power supply: %d\n", ret);
    		goto err_dev;
    	ret = sysfs_create_group(&dev->kobj, &bq25120_attr_group);
    	if (ret < 0) {
    		dev_err(dev, "failed to add charge sysfs: %d\n", ret);
    		goto err_sysfs;
    	 * Interrupt pin is optional. If it is connected, we setup the
    	 * interrupt support here.
    	ret = bq25120_irq_init(bq25120, client->irq);
    	if (ret < 0) {
    		dev_warn(dev, "failed to initialize IRQ: %d\n", ret);
    		dev_warn(dev, "disabling IRQ support\n");
    	return 0;
    err_sysfs:
    	bq25120_power_supply_unregister(bq25120);
    err_dev:
    	return ret;
    static int bq25120_remove(struct i2c_client *client)
    	struct bq25120_charger *bq25120 = i2c_get_clientdata(client);
    	if (bq25120->irq) {
    		bq25120_irq_disable(bq25120);
    		free_irq(bq25120->irq, bq25120);
    	sysfs_remove_group(&bq25120->dev->kobj, &bq25120_attr_group);
    	return 0;
    static const struct i2c_device_id bq25120_id[] = {
    	{ "bq25120", 0 },
    MODULE_DEVICE_TABLE(i2c, bq25120_id);
    static struct i2c_driver bq25120_driver = {
    	.driver = {
    		.name = "bq25120",
    		.owner = THIS_MODULE,
    	.probe        = bq25120_probe,
    	.remove       = bq25120_remove,
    	.id_table     = bq25120_id,
    module_i2c_driver(bq25120_driver);
    MODULE_DESCRIPTION("bq25120 battery charger driver");
    MODULE_AUTHOR("TI BMS software tools team");
    MODULE_LICENSE("TI BSD");
  • Dear Gautham:
    Can you kindly tell me what's the code used for? It seems like a code working in the linux environment? Thank you.
