BQ24616 LED indicators
I use the product BQ14616 in my design and it work well, I just have one problem, the STAT2 pin who indicate the end of charge is allway OFF even if the battery voltage is max and the STAT1 is alway ON.
In my design, the TTC signal is pull down.
When i used the eval board, I saw a difference when the signal TTC is pull down or up or float but the Stat2 signal never changed!
What is the problem?
Best regards
