In customer application, inductor will decrease to 1uH at some cases which inductor is not so good, so HW want to know What our IC will behavior at this case.
In my opinion, 1uH will increase current ripple which may bring larger Vout ripple and trigger current limit. I’m wondering if it will make the Vout oscillate since the inductor you recommend should be related with loop stability. is 1uH can achieve stable loop?
Also is there any hidden register or method that can report the issue if using smaller inductor?
please kindly add your commends.
