TPS3828-33 timing at Power ON
Once Vdd ramps above 1.1V into a valid operation range, what is the max time that will take for the reset output to be valid?  It does not appear that this time is explicitly specified in the datasheet.  Thanks!
  • Hi ,
    You are correct that we did not specify this delay. As with the other delays, overdrive will play a critical role the propagation delay. The faster that Vdd ramps up, the quicker /RESET will be valid.
    Very Respectfully,
    Ryan
