BQ40Z60 SYSPRES and LED
Other Parts Discussed in Thread: BQ40Z60
Several posts indicate that the BQ40Z60 datasheet pinout for SYSPRES (pin 15) and the ALRET (pin 14) are swapped (SYSPRES should be p14, ALERT should be pin 15, like the EVM.)
The question is - are the TRM http://www.ti.com/lit/ug/sluua04c/sluua04c.pdf register settings in section 6.2.1 correct? SYSPRES and pin 14 are both related to pin 15 for the ESHUTBUT bit.
How does one set the register bits for SYSPRES control AND for LED Display Button Control - just like the EVM? Is an internal pull-up provided for the LED button press?
