TPS65930
Other Parts Discussed in Thread: TPS65950
Hi All,
We'd grounded BCIAUTO ball in TPS65950, and need to use the BCI itself.
Have you ever faced w/ same problem. What would you suggest to solve the problem in terms of SW ?
Ramazan
    In main charge you will not have an issue. In case you attempt to use CV mode then you will have issues as the pre-regulation for internal VBAT node will not function. We do not recommend using CV mode as it was designed for test purpose only and we have seen problems with this on different platforms.
    Gandhar.
