Hello Team,
As per figure 42 in the TPS92691 datasheet, for Buck-Boost mode OVP circuit, base of PNP transistor connects to LED+ and Emitter is pulled to VIN through a resistor.
On the other hand, as per figure 26, base of PNP transistor is connected to VIN and emitter is pulled to LED+ through a resistor.
Which circuit is correct? Formula 43 is applicable for which configuration?
Mahendra
