Hi all
We are looking for the device(DCDC) which is Input 5V Output 0.2V/0.2A.
If you have some advice, could you let us know?
Kind regards,
Hirotaka Matsumoto
Hi all
Kind regards,
Hirotaka Matsumoto
Chris san
Thank you for your reply.
Yes, the load need 0.2V.
-Input voltage 5V
-Output voltage 0.2V/0.2A
You can use the SS/TR pin on a device like TPS62097 to regulate below the nominal FB pin voltage.
Or you can use an external reference voltage to bias down the FB pin voltage to achieve lower Vouts
->We can't understand well. Could you let us know detail? For example, TPS62097's VFB is 0.8V.
We need your help.
Kind regards,
Hirotaka Matsumoto
