bq34z100-g1EVM does not go to updateStatus 05 after 1st discharge in IT Enable
Other Parts Discussed in Thread: BQ34Z100
I want to complete a "clean" IT learning cycle. Knowing I had some incorrect params for my battery pack, I reprogrammed the bq w/ bq34z100_G1_v0_16_build_17.srec.
Then:
-> set the chemistry for LFP26650P (0x401)
-> set the parameters that I believe best describes the battery pack and operating range we use in our products.
-> set AGND and VOLSEL
-> set the applied voltage
-> run CC and BOARD calibration
-> start IT enable, and run 1st charge.
-> ran 1st charge and discharge cycle. updateStatus remains 04 but OCVTAKEN has responded correctly and IT ENABLE mode is now off.
The log for the cycle is attached, any suggestions ?
thanks!
evmlog_ITen-cycle1.log
