Fusion Digital Power Designer 2.0.159.0 error
Other Parts Discussed in Thread: UCD90160
Hello Team,
I have a customer who is using the Fusion Digital Power Designer 2.0.159.0 to program the UCD90160. The tool initially worked but later it crashed  when they tried to right to hardware.
Here is what they said:
"I believe it crashed when I tried to right to hardware. It said there was something wrong with the design. It gave me the error message I sent you. Then the Fusion tool shut down. I was not able to read the design out of the UCD90160. I had to go to my hard drive and reload an earlier version of the design."
Error Log is attached herewith. Is there a work around or any patch available for the latest version of this tool.
Thank you for your time.
Kishen Someshwar
Application: Fusion Digital Power Designer 2.0.159.0
Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
.NET Runtime: 4.0.30319.34209
Memory Used: 216.00 MB
Exception
System.NullReferenceException: Object reference not set to an instance of an object.
   at TIDP.PMBus.Parts.UCD90XX.f.a2()
   at TIDP.WinForms.Apps.DPGUI.dz.aj2()
   at TIDP.PMBus.ParameterControl.d.af()
   at TIDP.WinForms.Apps.DPGUI.dz.jm()
   at TIDP.PMBus.Parts.UCD90XX.f.a(ParameterList A_0)
   at TIDP.PMBus.Parts.UCD90XX.f.a(Object A_0, c A_1)
   at TIDP.PMBus.Commands.f.a(e A_0)
   at TIDP.PMBus.Commands.f.a()
   at TIDP.PMBus.Commands.f.a(Object A_0, EventArgs A_1)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Loaded Assemblies
Com.Muegel.Misc
   Version: 2.0.88.27976
   Info Version:
<empty>
   Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Com.Muegel.Misc.DLL
   Public Key Token:
Com.Muegel.WindowsApp.Win32API
   Info Version:
<empty>
   Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/Com.Muegel.WindowsApp.Win32API.DLL
   Public Key Token:
DevExpress.Data.v6.2
   Version: 6.2.10.0
   Info Version:
<empty>
   Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.Data.v6.2.DLL
   Public Key Token: 79868B8147B5EAE4
DevExpress.Utils.v6.2
   Version: 6.2.10.0
   Info Version:
<empty>
   Location: file:///C:/Program Files (x86)/Texas Instruments/Fusion Digital Power Designer/bin/DevExpress.Utils.v6.2.DLL
