A related question is a question created from another question. When the related question is created, it will be automatically linked to the original question.
How can I reset XCCH and XDSG? .srec file attached in .zip format.
I programmed your srec and was able to turn the FETs on after I sent the FET_EN command. Make sure that the SYSPRES pin is connected to VSS (PACK-) or set the NR bit to 1.
