Hi
This appliacation is a notebook.
When notebook in S4 or S5 status, it will disable TPS2546.
My customer would like to plug device in and wake up TPS2546 for charging device.
Could TPS2546 can support this function?
How to do that?
Thank you
Hi
How to do that?
Thank you
You can find that information in the datasheet in the Power Wake section (starting on page 20).
TPS2546 won't be able to support a wake function when the EN pin is low. In order for the mouse/keyboard wake function to work, EN must be high. VBUS is not on to power the HID when EN is low so the HID could not wake up the system via the D+/D- lines unless maybe it was battery powered.
