When selecting an inductor for this device, does the saturation level need to be above 11A since the current limit is not adjustable?
Is there an issue with saturation point of 4a for a 1A rail?
TPS54620 is cycle by cycle only. The device will keep switching, probably at minimum on time and near zero volts out, but the current will be at he maximum. As the inductor saturates, the p-p ripple current will increase a lot. Most modern inductors have a rather soft saturation profile, unlike some coils where the inductance would rapidly fall to near zero. You probably just need to check the specific inductor you are considering. Don't forget the heating current. You may find that the inductor gets hot enough to flow the solder and fall off the PCB (ask me how I know about this).
