Hi Everyone,
I am having an issue where sometimes the BQ34Z651 changes the Full Charge Capacity to a value much smaller than what it should be (17000mWh vs. 84000mWh). This has the roll-on effect of causing charging to terminate much earlier than expected.
I have not been able to identify what is causing this and as this value is modified internally within the device I am unable to reset it. Following a couple of charging/discharging cycles it seems to figure out this error on it's own and the Full Charge Capacity returns to a reasonable number. But as this issue seems to occur randomly I am unable to fully test whether this is the case.
So my questions are:
What is the most likely cause of his issue?
Is there any way I can force the device to re-calculate this value so I don't have stunted battery for a number of cycles?
David
