I use this device in my design and I have two questions:
1. I connect pin 20 (NC) to +5V (for compatibility purpose). Could I have problems?
2. The datasheet shows how to adjust the voltage level for channel 2 through a voltage divider. This voltage divider set the voltage level at REFIN2, using VREF2 for that. Can I use VREF3, instead of VREF2, for setting the output voltage level?
Thank you in advance,
Fernando.
