Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TPS51367 Tj max; Higher ambient Temp
Other Parts Discussed in Thread: TPS51367
Hi Team,
what is the maximum recommended Tjunction for TPS51367? The datasheet only specifies ambient temp. Is it possible to use TPS51367 at higher ambient temps (95°C maybe 100°C) if the junction temperature is within the limits?
SF
