Hello Team,
I have a question from a cusotmer...For EN on devices like your TPS54821 when EN is an internal current source a pull down cannot be used. I assume for these EN I use the FPWM pin so the output is ALWAYS low until the UCD9090 enables it. Can you confirm?
Question is: can we actively drive TPS54821’s enable pin to 3.3V to enable the device?
Thanks for the help on this.
Dan Nitta Mackay - TSR Ottawa Canada
