BQ40Z50-r1 : CUV protection and precharge
Expert 7280 points
Other Parts Discussed in Thread: BQ40Z50-R1, BQ24616
Dear team,
Could you help me figuring out the best way to proceed when using BQ40Z50-r1 + BQ24616 (integrating a battery detection state machine) when the battery is discharged enough for the CUV protection to disable the discharge path ?
The current issue is that when CUV is active, the charger does not detect the battery until the CUV condition is removed and DSCHG FET is turned ON again. I suppose this could be linked to the fact that the charger is probably seeing an excess of 1*reverse FET diode drop + 125mA*precharge resistor ?
This takes a lot of time since the charger is then only charging through its battery detection state machine, at 120mA every few seconds.
Did you run into such issue before ? What would be your recommendations ?
I have some more information I could share but would prefer to take it offline.
Thanks a lot!
PA
