Can I use it with +3.3V Vds in a voltage to current converter?
Hello Minglai,
I believe that the CSD23381F4 FemtoFET is covered by the NexFET group. They would be able to best answer specific questions about applying the device. However, based on the CSD23381F4 datasheet specifications it does look like it would be useable in a +3.3 V voltage-to-current application, in conjunction with a low-voltage op amp.
If you would like to pose your question to the NexFET E2E group here is a link to their forum:
Regards, Thomas
PA - Linear Applications Engineering
