tps25921A SS questions
Other Parts Discussed in Thread: TPS25921A
 Hello guys,
 One of our customers is considering to use TLC25921A. The customer wants to know about the follwings.
 Could you please give me your answers?
 Q1. What is changed by SS capacitor value? Is it VOUT rising time only? Is Inrush curret changed to achieve the VOUT rising time?
 Q2. Is it no problem that SS terminal is open?
 Q3. Do you have any recommended SS capacitor value?
 Your reply would be appreciated.
 Thank you and best regards,
 Kazuya Nakai.
  • Hi Kazuya,
    SS capacitor value determines the Vout ramp time and also controls inrush current according to equations 2 and 3 in tps25921A datasheet.
    The SS pin can be left floating to obtain a predetermined slew rate (tSS) on the output. When terminal is left floating, the device sets an internal ramp rate of ~50V/ms for output V(OUT) ramp.
    Appropriate value of SS capacitor has to be chosen for successful startup. It depends on your system voltage, output capacitance and load at startup.
    Can you provide details to suggest suitable SS capacitor value
    Rakesh
  • Hello Rakesh,
    Thank you for your reply and kind words.
    I could understood it well.
    If I need any additional help from you, I will inform again.
    Thank you again and best regards,
    Kazuya Nakai.
  • Sure Kazuya,
    Rakesh
