Is there an alternative to TLV70033 that has an internal pulldown on the enable pin?
I am using the TLV70033 and have an initialization issue because the enable pin in my implementation is controlled by a microcontroller. On power up, the regulator can turn on for up to 30 ms until the micro initializes and pulls the enable pin low. I am adding a pull down resistor but wondered if there is an alternative TI part that already has the enable pin pulled down to avoid this situation.
