25W PD solution for POE
Other Parts Discussed in Thread: TPS23754EVM-383, TPS2378EVM-602, TPS2378
               if customer need 25W PD for POE with 4 pair cable. Do we have any solution to meet requirement? Thank you.
BR
Patrick
  • Hi Patrick,
    If you have a method for your PSE to turn on pairs 3 and 4, you can use a typical 25W PD solution. Like TPS23754EVM-383. I recommend taking the TPS23861EVM and using its GUI to manually turn on pairs 3 and 4 to test this.
    If looking for a dual PD solution. I recommend looking at the TPS2378EVM-602 and keeping the TPS2378 front end and changing the converter to a 25W solution. TI Designs is a great start when looking for a 25W converter only solution geared toward your power requirements.
