TPS26600 Design Calculator vs Datasheet?
There seems to be an error in the TPS26600 Desing Calculator or in Equation 2 (pg 20) in the datasheet. If you use the default values in the spreadsheet it recommends 0.220uF, but if you use the equation in the datasheet it would give you 27.5nF (approximated to 22nF).
Which is the correct value?
