Hi Sir
we use TPS51116 in DDR power, but the vout will drop from 1.2V to 1.05V when we run heavy load(4 DIMM).
May you have some suggestion for us?
Hi Sir
Hi Bogey,
Can you check the voltage of VDDQSET pin (the voltage across R220) to see if it is 0.75V?
Qian
Hi Bogey,
I tested the EVM at below condition, and I did not see the problem at load conditions. The Vout is 1.2V and VDDQSET is 0.75V at either no load or load condition.
-DCAP mode (connnect COMP to 5V)
-VDDQ=1.2V (47kohm and 75kohm resistor divider)
-5Vin
Can you replace TPS51116 controller to see if the problem is still there?
If the problem persists, can you send me the layout design file (not screen shot) to Q-CHEN AT TI.COM, so I can check if there is layout issue.
Qian
